Home Forums Products Stompboxes MixingLink weak signal/too much gain required Reply To: MixingLink weak signal/too much gain required
#148629
JWaltz
    Hi Charlie – You should be able to set Input Gain so the loudest input level flashes the green signal present. Then set Ouput Level for unity.
    The Mix Mode setting will also have an effect on the unity gain setting.
    Hope this helps
    joe waltz
