Home Forums Products Stompboxes MixingLink weak signal/too much gain required Reply To: MixingLink weak signal/too much gain required
#148690
mistercharlie
    Solved. The problem was a dodgy cable! The cable works fine in other pedals, but was causing problems when plugged into INST In on the MixingLink. I switched it for another one and the MixingLink works as it should, with unity gain at 12 o’clock and no hiss.
