Home Forums Products Stompboxes Where does the H9 SysEx Dump file go? How does restoring SysEx work? Reply To: Where does the H9 SysEx Dump file go? How does restoring SysEx work?
#148692
    There are no "slots" as such. The way it works is that the H9 will ignore Sysex messages with the wrong ID.
    I would STRONGLY recommend that you leave Sysex ID set to the default value on all systems (not just H9). Often, things stop working if you change this.
