Home Forums Products Stompboxes Stereo setup via 2 amps effects loops? Reply To: Stereo setup via 2 amps effects loops?
#148811
bohan
    VerodaClient wrote:
    I'm getting an odd, wet/dry, effect where one amp appears to have some of the effect and the other amp has just the wet signal. The routing on the H9 is set to "normal" though.
    What sound did you get without H9s? How do you split your signal to two amps?
