Home Forums Products Stompboxes Stereo setup via 2 amps effects loops? Reply To: Stereo setup via 2 amps effects loops?
#148820
bohan
    VerodaClient wrote:
    Sorry, I should have mentioned I'm splitting the signal with a Suhr buffer. Guitar into the input of the buffer and each output into the front of each amp. There's only one H9 and without it in the loops I get normal sound out of both amps.
    I don't really know what's going on in your H9. Normally, with Stereo Inputs, the dry contribution at Output 1 is from Input 1 and the dry contribution at Output 2 is from Input 2, thereby maintaining the original signal stereo image. I would suggest you check the routing mode again, and the voice mix (delay mix parameter in delay algorithms). If the voice is A10 + B10, it should work as what you expect.
