Home Forums Products Stompboxes Loop Decay with Playback on TF/H9 Reply To: Loop Decay with Playback on TF/H9
#148850
bohan
    Vaidas wrote:
    But is there a way to do that on a mono setup?
    Maybe there is but I can't think of one. You may try to use an expression pedal to map the mix parameter so you can control the playback fading manually…
