Home › Forums › Products › Stompboxes › Stereo setup via 2 amps effects loops? › Reply To: Stereo setup via 2 amps effects loops?
March 31, 2018 at 1:08 pm
#148853
I thought it worth mentioning that you may need to check that the send levels of each amp are the same. You can do this in the H9 Control App under “Pedal Settings” … “Input Gain and Level Meters”.
