Home Forums Products Stompboxes Pitchflex alg is glitchy Reply To: Pitchflex alg is glitchy
#148863
camn wrote:
Well, if you can’t see the relevance, I probably can’t help you troubleshoot this. Maybe someone else has some ideas. Good luck!
As I mentioned, this quantized pitch change via exp pedal is independent of Bluetooth status; it occurs in both states (and hotswitch one is always smooth, even when the bluetooth is on). Being so, I can’t see how this comparison would offer any additional help.
As a side note, same steps are audible when the pitch is changed by turning the big black knob too.
Nevertheless, thanks for your kind wishes : )
