Home Forums Products Stompboxes mono or stereo per preset Reply To: mono or stereo per preset
#148882
alihai
    Hey thanks for replying and sorry if my post was confusing.
    Basically I’m using one of the delays in the h9 with two delays each at a different tempo.
    I play with a stereo rig (2 amps), and my problem is that delay A plays only on the right amp and delay B only form the left amp.
    Would it be possible to have both delays playing on both of them?
    The same it’s even more prominent when I use Ultra Tap (I think I’m using the “stutter” preset).
    Would it be possible to change this here as well?
    At the same time in another song I use an effect that does kinda the same bouncing between the two, but in that case I like the way it is, that’s why I was asking if it can be set differently for each effect.
    Please let me know if you need more info
