Home Forums Products Stompboxes Mono vs. Stereo (ie. Pre/Post mode) Reply To: Mono vs. Stereo (ie. Pre/Post mode)
#148952
Late report…
Fist gig with H9…. Went there with assumptions of everything would be fine even if give up the stereo setup.. I even couldn’t compare them. Oh boy, a huge noise ruined everything…. Kinda odd, because spending some 10 years as a sound engineer you could diagnose a noise (most probable source etc.) but that was an odd one… similar to a ground loop but kinda different… Saw tooth buzz mixed with white noise : ) ….
It was even happening when I touch the ground of the line out cable’s shield while touching the H9 body.. Strange thing is… all the other instruments was fine… keyboards… guitars etc…
Maybe I should bring a DI box next time…
Cheers
Q
