Home Forums Products Rackmount I need help updating my Eclipse to V4 Reply To: I need help updating my Eclipse to V4
#149037
nickrose wrote:
As far as I know, they are all US made (some had imported metalwork). Probably just changed the sticker.
Ok, thanks. I´ll update the Eclipse using a Compact Flash Card. What are the sizes that work? I´ve read that the modern ones with over 1gb will not work with the Eclipse, and that i should stick with the ones between 512mb-1024mb. Is that correct? Are there any other details i should consider before buying a Compact Flash Card to do the update?
