Home › Forums › Products › Stompboxes › Pitchfactor Diatonic Key Switching › Reply To: Pitchfactor Diatonic Key Switching
April 30, 2018 at 3:31 am
#149082
There are two ways.
You can use an Aux Switch defined as “Performance Switch” with algos that support it, or attach a momentary switch to you Expression Pedal leads for ‘instant expression’ for algos that don’t.
I’d use the first, and I’d use PitchFuzz
On my patch above you just have to assign the alternative voicing to the ‘Hotswitch’ instead of the expression pedal.
