Home Forums Products Plug-Ins updated plugins but there appearing disabled in ableton projects Reply To: updated plugins but there appearing disabled in ableton projects
#149090
commonground
    Disregard, I have solved the issue. Bloody gobbler!
    Thanks..
    commonground wrote:
    Having a little crisis here,   Ive updated all my eventide plugins via gobbler and they all work when i open them in a new ableton session BUT they are coming up as disabled in all my projects.   I also get this message in the image attached when i open my projects containing instances of Eventide. So to sum up my AU plugins in my projects aren’t opening and can’t be found when i open projects but If i open a new instance of the plugin it runs fine.  I believe there must be a path/naming issue that has occured when i updated.
    I really need these projects up and running with all the hard work ive done with them, I use eventide alot for sound design so my tunes will never sound the same without the work ive already done.
    opperating system: OSX mavericks
    Daw:  ableton 9
    any help would be greatly appreacited!
    thanks
    Grant
