Reply To: Configuring H8000FW for dual-stereo using ADAT
Home Forums Products Rackmount Configuring H8000FW for dual-stereo using ADAT Reply To: Configuring H8000FW for dual-stereo using ADAT
#149104
t_tangent
Thanks for the replies, and the routing diagram is very useful. I will try this and the other routing you suggested earlier as soon as I can and will report back on my results.I haven’t experienced crashing of the H8000FW when switching to 96 from 48 like paddyryan has. Paddy, what audio interface are you using, and do you also have firewire and AES/EBU connections to your DAW. DId you try switching to internal clock and then changing to 96kHz? Sometimes working backwards is the only way to find out what is causing the problem. Would be good to hear if you have any success with what Nickrose suggests. Good luck.
