Home › Forums › Products › Stompboxes › Mixing Link Power Supply and Headroom › Reply To: Mixing Link Power Supply and Headroom
May 3, 2018 at 10:15 pm
#149143
Hi Joe,
The gain switch setting is set to low. The issue occurs with the button in both positions (low and high), where clipping occurs 20-30 dB below where the peak should be (red peak LED never comes on).
The only difference is that on the high gain setting this occurs with the input gain knob turned all the way down, and on low gain it occurs with the input gain knob set to about 12:00.
