Home › Forums › Products › Stompboxes › Expression Pedal not going 0-100 with H9 Max › Reply To: Expression Pedal not going 0-100 with H9 Max
May 7, 2018 at 1:28 pm
#149180
– Expression Pedal Calibrate (ON, OFF) Press the HOTKNOB button to select. Select OFF to disable automatic Expression Pedal calibration. Press the PRESETS button once to back-up one level to UTILITY menu. Press the PRESETS button twice to go to top level System menu.
Leave it ON once to calibrate the pedal. Full heel, then full toe … maybe a couple of times, to be certain. Once the correct expression pedal range is locked in, set the system [PDLCAL] parameter to OFF.
