Home Forums Products Stompboxes Connecting two H9’s stereo or mono? Reply To: Connecting two H9’s stereo or mono?
#149196
bohan
    mistercharlie wrote:
    Is there any advantage to using a stereo connection between the H9s, if the overall signal chain is mono?
    Let's say if you have a stereo delay algorithm on the first H9 and a pitch-shift on the second H9. If you want to hear two delay lines with different pitches, you can achieve that by using a stereo connection between the H9s.
    It's not a good example though since you can use one pitch algorithm to do what I described above…But I guess there are other cases. It just depends on what sound you need.
