Home › Forums › Products › Stompboxes › Expression Pedal not going 0-100 with H9 Max › Reply To: Expression Pedal not going 0-100 with H9 Max
May 10, 2018 at 3:32 pm
#149223
I thought it worth mentioning that in my case (Dunlop DVP3), if I insert the jack while the H9 is on, I usually get a maximum calibration from 0 to about 87-92. If I turn the H9 off and back on, it will calibrate 0 to 100. Probably has something to do with the ring voltage making contact as the plug is inserted.
