Home Forums Products Stompboxes Timefactor- no sound/signal even through bypass Reply To: Timefactor- no sound/signal even through bypass
#149283
    After initialization, the unit will default to relay bypass. There is not much to go wrong with this – if you can hear the relays click, it is probably working.
    If you hear the click, it is most likely that you have some kind of external cabling problem.
