Home › Forums › Products › Stompboxes › How to set all my presets 100% wet? › Reply To: How to set all my presets 100% wet?
May 22, 2018 at 10:06 pm
#149299
gogotina wrote:
Yes, I've tried it. Also Kill Dry Audio is enabled, but… All my effects are around 20% not 100%. Why? 🙂
Because your current global mix is 20. If you turn the mix parameter to 100, then all your effects' mix will be 100. However, this global value won't be saved with each preset. When you turn off the global mix, the mix is determined by each preset's mix value.
