How to set all my presets 100% wet?
Home › Forums › Products › Stompboxes › How to set all my presets 100% wet?
    • #114747
      gogotina
        Now I am using H9 with Lehle Parallel L and I would like to have all my stored presets 100% wet. Is there a simple solution for that? Lehle have mix so it would be easier for me to control it that way. Thanks!
      • #149276
          Have you tried the "global mix" setting ?
        • #149294
          gogotina
            Yes, I’ve tried it. Also Kill Dry Audio is enabled, but… All my effects are around 20% not 100%. Why? 🙂
            • #149299
              bohan
                gogotina wrote:
                Yes, I've tried it. Also Kill Dry Audio is enabled, but… All my effects are around 20% not 100%. Why? 🙂
                Because your current global mix is 20. If you turn the mix parameter to 100, then all your effects' mix will be 100. However, this global value won't be saved with each preset. When you turn off the global mix, the mix is determined by each preset's mix value.
