Home › Forums › Products › Stompboxes › Tracking changes in Output Volume & Input Volume made by MIDI CC › Reply To: Tracking changes in Output Volume & Input Volume made by MIDI CC
May 25, 2018 at 5:32 pm
#149321
gkellum wrote:
The input gain from UTILS in System Mode is different than the input gain that’s MIDI controllable. The input gain in System Mode is gain that can be applied before the ADC converter to boost the signal a bit if needed to improve the conversion quality. That gain is limited to only 12dB and it’s cancelled out on the output with a corresponding cut so that there’s zero net change in gain.
A belated thank you!
