Home › Forums › Products › Stompboxes › Choppy: moog ep-3 -> H9 -> xmit cc #14 (xmit ch. #4) -> boss es-8 (rcv ch#4) -> assign cc#14 : exp 2 out -> moog mf drive › Reply To: Choppy: moog ep-3 -> H9 -> xmit cc #14 (xmit ch. #4) -> boss es-8 (rcv ch#4) -> assign cc#14 : exp 2 out -> moog mf drive
#149351
bohan
    rorytheherb wrote:
    I couldn't find the monitor in the ES-8 Editor but I looked in Midi Ox. A heel to toe sweep (0 – 127) is 00 to 7F in hex, and a toe-to-heel sweep is 7F to 00. Either way, the H9 is sending on average 36 messages.
    Have you tried calibrating your expression pedal on H9? You can do this in H9 Control: "Pedal Settings" -> "General Settings" -> "Pedal Calibration Disabled" -> switch it to "YES" and to "NO" again, and then move your expression pedal from heel to toe. H9 will learn your expression pedal and calibrate it. Let me know if this works.
