Home Forums Products Stompboxes suggestions needed on the best way to do simultaneously tap tempo with my H9 and TF via FS3X Reply To: suggestions needed on the best way to do simultaneously tap tempo with my H9 and TF via FS3X
#149427
    You would want to use a TRS (stereo) Y adaptor. The switch would then control both units.
    But, you would be creating a ground loop, so might have to fiddle with the wiring to avoid hum.
    A switch will work better for tap than MIDI, which is inclined to be a little "rubbery."
