Home Forums Products Stompboxes H9 Pre/Post relay bypass Reply To: H9 Pre/Post relay bypass
#149445
bohan
    nati.taub wrote:
    Not sure if it has been answered already, but when using relay bypass with pre/post routing is it still actually in relay mode? or because the pre/post mixing is happening in the DSP the signal has to be converted? Thanks.
    DSP bypass is used in Pre/Post routing mode regardless of what the bypass setting is.
