Home Forums Products Stompboxes Real stereo in H9? Reply To: Real stereo in H9?
#149446
bohan
    teabandito wrote:
    Hello, I have a question: does any algorithm in H9 have a real stereo? For example when the delay with one time sounds from output 1 and the another time from output 2? Or arpeggiator which plays som notes from output 1 and others from output 2? I am now playing into amp with stereo loop and I can't really hear any difference between the mono and stereo cable connection. Your opinions?
    Of course. Most algorithms in H9 are real stereo effects. I'm not clear about your setup. Are you using 1 amp or 2? How do you monitor the two outputs? Please also try to adjust the DELAY MIX parameter for delay algorithms. You should be able to tell the two voices if you have a proper setup.
