Home › Forums › Products › Stompboxes › H9 Pre/Post relay bypass › Reply To: H9 Pre/Post relay bypass
June 9, 2018 at 10:35 pm
#149460
nati.taub wrote:
so it does keeps the relay bypass in pre/post routing? you got me confused 🙂
I'm sorry for confusing you…Yes, if your bypass mode is set to Relay. The bypass mode in pre/post routing is same as normal routing. You may set the bypass mode to DSP, Relay, or DSP+FX (effect tail).
