Home › Forums › Products › Stompboxes › Strange mix behaviour › Reply To: Strange mix behaviour
June 10, 2018 at 10:11 pm
#149471
gcrooks wrote:
I was having the same issue. I’m glad I read this. I did not know that “global mix” on would transfer the mix from the previous patch. How is that “global?” Anyway because I am using an expression pedal and have it set to “mix” on another patch apparently that is why the mix settings were going to zero and would not save. Global set to off, seems to have fixed the problem.
Global Mix means that the system owns the mix value, not the preset. If you load another preset, the mix value will not change.
But, if you change the mix value, this will become the new mix value for eternity (unless you change it again).
