Home Forums Products Stompboxes H9 Wish List Reply To: H9 Wish List
#149492
bansta
    I’m in DSP+FX-Bypass. (I’ve tried the DSP-bypass as well)
    The volume is controlled per MIDI CC.
    When the H9 is bypassed, the volume goes up to the level, stored in the current preset. (Normally I’ve got it dimed by a MIDI-Volume pedal)
    My wish is to have the voulme on the same level as it was immidiately before the bypassing with no jumps.
    Cheers
    nickrose wrote:
    bansta wrote:
    When the H9 is bypassed the expression pedal and MIDI controller are being ignored and the output volume remains set to patch value with no reaction on pedal movements. Did I miss some setting to change this behaviour?
    bohan wrote:
    bansta wrote:
    Global volume control, wich remains active in the bypass mode
    You can use an expression pedal or a MIDI controller to control the output volume globally.
    I’m guessing you are in RELAY BYPASS mode, in which case the unit is effectively out of circuit. Set it to “DSP BYPASS” if you want it to be active while bypassed.
