Home Forums Products Stompboxes H9 looper hold function Reply To: H9 looper hold function
#149527
bohan
    taasali wrote:
    Is it possible to use the looper like the boss dd7 loop? To record you hold down for as long as you want to record, when you lift off your foot it starts playing the loop. Is this possible?
    Boss DD7 is a single-footswitch delay pedal so you need to hold it to activate the looper mode. The LOOPER algorithm on H9 works like a common loop pedal. You press the left footswitch to record, and press it again to play the loop. However, the DUBMODE parameter controls the way how Dubbing operates. If the DUBMODE is set to LATCH, now pressing left footswitch will toggle DUB -> PLAY -> DUB -> PLAY…; If it's set to PUNCH, you hold down left switch to dub, and lift off your foot it starts playing the loop
