Home › Forums › Products › Stompboxes › New SPACE, Tempo not steady ? infos needed :) › Reply To: New SPACE, Tempo not steady ? infos needed :)
OMG… i love your sounds but things seems to be complicated before (perhaps) going easy.
i exchanged my space in store (very near serial number) and the problems seem the same.
1. visual tempo is sometimes shifting one 8th (not only, sometimes it’s a more groovy fourth 16th or third 8th triplet). To be sure i even verified using a DB88 steady metronome. no doubts. i tried changing current source but it’s all the same.
2. i can’t usb connect to h9 control (i still don’t even try midi connections with these problems)
it says device not found and doesn’t recognize my space as connected.
it says “retrieved 0 eventide devices” in eventide direct updater.
i verified with a good old program (Usbdeview) and the space is well recognized there as a USB composite device (normal it was the same with the precedent one.)
i tried a Clear setup but nothing changed.
sincerely i feel a bit tired about your hard/soft/wares issues.
Show More...Is this a bad serie for frenchies ? i guess not 😉 bad joke
