Home › Forums › Products › Stompboxes › New SPACE, Tempo not steady ? infos needed :) › Reply To: New SPACE, Tempo not steady ? infos needed :)
June 29, 2018 at 1:37 am
#149588
O2LAMJU wrote:
Timefactor would be second step in my pedalboard renewal.
If the TimeFactor LED is stable..you could set it up as your clock master… and tape over the LED on the Space. Use the Timefactor LED to visually sync.
Or.. any other MIDI gear, if you have it or want to add it.
