Home › Forums › Products › Stompboxes › New SPACE, Tempo not steady ? infos needed :) › Reply To: New SPACE, Tempo not steady ? infos needed :)
well i use a mpc1000 sometimes (synced perfectly with sonar daw) and before throwing back (hum) the space to my pedal shop i wanted to try syncing the space to see if it at leasdt work synced as a slave.
Only one midi cable from mpc midi out to space midi in, i’ve set up space to midi in “on”, i tried with or without midi clock filter, with or without global tempo, nothing works. What am i supposed to do ?
On mpc i disabled all other sync in/out option, then activated OUT B (to Space) as “Clock” (and not Timecode) with a 30 framerate (well i also tried with other framerate)
i also tried with Cakewalk Sonar (as master naturally), nothing works.
eventide says visual tempo is not important cause it doesn’t change the sound… well for a 520€ reverb pedal i hoped to have a full functionnal gear,
but if i can’t even sync it with my midi gear and daw how can i have a precise sound ?
i found someone had the same problem but no one from eventide even tried to answer https://www.eventideaudio.com/community/forum/stompboxes/space-and-midi-clockexternal-tap
(and please don’t tell me “buy a timefactor” to have fully functionnal “space”)
i hope again i’m missing something
Show More...Show Less...
