Home › Forums › Products › Stompboxes › Using Mixing Link as input for two instruments with very different gain › Reply To: Using Mixing Link as input for two instruments with very different gain
July 3, 2018 at 7:05 pm
#149628
hi clundeen,
Depending how you are using the FX loop, One solution could be to plug the synth into the FX return (should have plenty of headroom for synth level) and use the MIX knob with MIX Switch set MIX to mix between the trombone mic and the synth. You could have XLR out go to FOH or DAW A/D input and have Amp Out got to a monitor or other destination with it's own level control.
Yes, ideally the instrument input should have its own level control to mix it in with the mic input.
Hope this helps.
joe waltz
eventide
