Home › Forums › Products › Rackmount › H9000–Does TF Looper work re. start/stop via external midi time code? › Reply To: H9000–Does TF Looper work re. start/stop via external midi time code?
July 11, 2018 at 3:40 pm
#149674
Thanks for the reply–I didn’t make it clear that I AM sending midi clock out from my daw to the H9k., I have the H9k set to receive midi clock in the tempo section, but when hooked up to the daw that’s sending midi clock, and I press play on the H9k looper, it plays rather than waiting for the daw to start it. It doesn’t seem to be recognizing the start command from the daw.
