Home Forums Products Rackmount H9000 TF Basic Looper-odd foot switch behavior Reply To: H9000 TF Basic Looper-odd foot switch behavior
#149712
brysava
    Thanks Patrick, I used your quick map instructions to assign the pedal to “record”, and that part is solved–the looper now goes into record on the first press. But I’m expecting the looper to act the same as when I hit “record” manually, which is: hit record once=goes into record; hit record again=goes into “dub”, hit record again=goes into play. But with the pedal, after the first hit and it goes into record correctly, the next hit of the pedal=a split second in “dub” but instantly into ‘play”. Thereafter it requires 2 hits of the pedal to get to “dub” etc.
    Thanks
    Bryan
