Home › Forums › Products › Stompboxes › Parallel FX Set Up: kill dry = yes but dry signal present › Reply To: Parallel FX Set Up: kill dry = yes but dry signal present
July 18, 2018 at 4:08 pm
#149725
In the H9 App when I select the pedal from settings there is an option to select YES/NO to enable the bypass settings to reflect the method selected under Bypass Mode.
