Home › Forums › Products › Stompboxes › Parallel FX Set Up: kill dry = yes but dry signal present › Reply To: Parallel FX Set Up: kill dry = yes but dry signal present
I’m trying to set up a parallel FX loop and want to completely kill the dry signal through my stompbox.
I believe you should use a Serial FX loop if you want to completely kill the dry signal.
Hi & Thanks Bohan
Ah? Am I missing something? Is there a Serial FX loop setting on the Eventide guitar pedals?
Otherwise I’m slightly confused.
I have my clean signal and I want to blend that with my FX pedals using an Xotic stereo blender. Consequently, I want only 100% wet from the FX (0% dry) so as to avoid phasing issues and increased volume (which happens if 2 of the same clean signals are combined in phase, which I currently have). Surely that’s a parallel FX set up???
