Home › Forums › Products › Rackmount › H3000 Output Level Problem › Reply To: H3000 Output Level Problem
July 18, 2018 at 11:12 pm
#149735
After checking all the ribbon cables inside I would be sure you have properly wired XLR cables. The h3000 is reverse phase from what is now the commonly accepted xlr standard. If you have the h3000 interacting with other gear this is important. Unbalanced sources – which should not be plugged directly into a h3000 in the first place – don’t send anything on the negative channel.
