Home › Forums › Products › Stompboxes › Mixing link – Problem? › Reply To: Mixing link – Problem?
July 20, 2018 at 9:42 am
#149754
Hi Kostas,
What is Gain Switch set to on the side of the unit? I could not figure this out from your video.
This should be pushed in – 'LO' gain setting. Otherwise you will have limited headroom by adding 20dB of extra gain causing signal overload.
The 'HI' gain setting is for ribbon mics or low-output mics.
email me
thanks, joe waltz
