Home Forums Products Stompboxes Preset changing with a boss es-8 usind midi comands Reply To: Preset changing with a boss es-8 usind midi comands
#149794
bansta
    I use a Boss ES5 (a little brother of the Boss ES8) to control 2 x H9. It works fabulous!  Even a volume pedal is connected to the Boss ES5 and sends MIDI CC to the H9, so that I don’t need to have it in the signal path. BPMs settings and the amp channel switching are controlled by BOSS ES 5 es well.
    Ramil7rodriguez wrote:
    I have an h9 max and want to buy pedal switcher. I’m considerind the boss es-8 because of the midi capability. I’m wondering if I’ll be able to make presets on the switcher that recall presets on the h9 so that I can change presets on the H9 when I select a preset on the switcher.
