Home › Forums › Products › Stompboxes › Urgent Advice needed for how to connect iPad to run H9 App with Time Factor › Reply To: Urgent Advice needed for how to connect iPad to run H9 App with Time Factor
July 30, 2018 at 7:39 pm
#149820
entreat69 wrote:
I'm in urgent need for help and advice regarding how to connect usb cable between iPad with the Timefactor's USB type B connector? This is to run the H9 Control App within iPad to backup and also tweak and upload my saved presets to Time Factor.
You just need to get an Apple camera connection kit so you can connect your iPad to a USB device. There are different ones depending on whether your iPad has a lighting connector or the older 30 pin connector.
