Home Forums Products Stompboxes Delay Algo idea Reply To: Delay Algo idea
#149824
William Middlemiss
    brock wrote:
    Check out the Resonator algorithm.  Leave the RESONANCE at 0 for a more ‘normal’ delay configuration.  “Hold” would translate to high feedback levels or FREEZE in this algo.  Here’s a loose example:
    https://www.eventideaudio.com/comment/31589#comment-31589
    It’d be similar to a tempo syn’d looper with the ability to phase the loop against itself after it was recorded. The unit I was referencing had 4 loops to do this and independent level control, beat placement and panning of each.
