Delay Algo idea
Home Forums Products Stompboxes Delay Algo idea
    • #114856
      William Middlemiss
        I had a unit years ago (which I dont want to name as theyre hard enough/impossible to find already) which had a tempo-adjustable (via internal bpm settings or external midi) 4 tap delay with adjustable feedback and a hold function.
        But one the unit was in ‘hold’ mode, the taps could be slid forward or back in beat subdivisions and very interesting rhythms could be made.
        Something similar in function for the H9 would be incredibly useful
      • #149802
          Check out the Resonator algorithm.  Leave the RESONANCE at 0 for a more ‘normal’ delay configuration.  “Hold” would translate to high feedback levels or FREEZE in this algo.  Here’s a loose example:
          https://www.eventideaudio.com/comment/31589#comment-31589
          • #149824
            William Middlemiss
              It’d be similar to a tempo syn’d looper with the ability to phase the loop against itself after it was recorded. The unit I was referencing had 4 loops to do this and independent level control, beat placement and panning of each.
