Home Forums Products Stompboxes Organising presets on multiple H9’s Reply To: Organising presets on multiple H9’s
#149889
mistercharlie
    I’ve been thinking about this too. Currently I’m always a bit confused about what’s where.
    If the same preset is on both pedals. I make sure to give it the same number/position on both. Other than that, right now I’m only using a fraction of the 99 available preset slots.
    My idea is that I’ll put a set of duplicated presets on both, say from 01-20, then let 21-99 be for each unit’s independent presets.
    What would be really cool would be a way to use MIDI to swap currently-active presets. Then you could quickly switch, say, pitch shift before dirt, to pitch shift after dirt.
