Home Forums Products Stompboxes Disable inverting preset change direction with HotKnob Reply To: Disable inverting preset change direction with HotKnob
#149938
bohan
    flamefork wrote:
    I'm using H9 with OX9. Right button of OX9 is mapped to preset decrement and I'm using Tap button for preset increment.
    The problem is, when I accidentally press HotKnob, both right buttons became preset decrement, and this is kinda stressful in the live situation.
    I would recommend you use two switches on the OX9 for preset decrement/increment, and use the right footswitch on the H9 for Tap. If the right footswitch is in Tap mode, pressing the HotKnob wouldn't do anything.
    By setting so, you can also load presets by pressing just one switch, instead of hitting the Active switch again to confirm.
