Home Forums Products Stompboxes Disable inverting preset change direction with HotKnob Reply To: Disable inverting preset change direction with HotKnob
#149939
bohan wrote:
I would recommend you use two switches on the OX9 for preset decrement/increment, and use the right footswitch on the H9 for Tap. If the right footswitch is in Tap mode, pressing the HotKnob wouldn’t do anything.
By setting so, you can also load presets by pressing just one switch, instead of hitting the Active switch again to confirm.
I need another button for Performance switch as I use it a lot, and I don’t need Tap feature 99% of the time, thus I use left OX9 switch for Perf and right 2 switches for increment/decrement.
