Home › Forums › Products › Stompboxes › Disable inverting preset change direction with HotKnob › Reply To: Disable inverting preset change direction with HotKnob
August 18, 2018 at 8:04 am
#149946
bohan wrote:
I’m suggesting you use the right footswitch in the tap mode. In this mode, the HotKnob won’t change the function of any switches. So you may use your 3 aux switches to Increment/Decrement/Performance, and hold both footswitches on the H9 to toggle tuner.
I would be happy to, but my problem with tuner is not that pressing HotKnob while holding 2 buttons would switch the direction, it’s that it would prevent tuner from turning on. And it’s like 50% of the time I hold 2 buttons for tuner I happen to press HotKnob accidentally.
