Home › Forums › Products › Stompboxes › I want a bypass patch › Reply To: I want a bypass patch
August 19, 2018 at 3:55 am
#149950
nickrose wrote:
If you save any preset when bypassed, and then load it from a MIDI PC, it will load bypassed. This may be what you need.
Ah, sorry, I should have specified I use one midi switch to toggle the H9s on and off, so even if I saved the effect off, when I hit the toggle the effect would kick in and then change the tone.
