Home › Forums › Products › Stompboxes › I want a bypass patch › Reply To: I want a bypass patch
#149952
bohan
    terich wrote:
    I should have specified I use one midi switch to toggle the H9s on and off, so even if I saved the effect off when I hit the toggle the effect would kick in and then change the tone.
    Off the top of my head, maybe the Looper algorithm? It might not work but worth a try.
    Set the MIDI mapping for "Toggle between active and bypass" instead of "Left Footswitch" because the Left Footswitch can trigger Recording
